跳转到主内容
Mac Pro First Generation Power Supply Unit Replacement
你所需要的
  1. Mac Pro First Generation Power Supply Unit Replacement, Case Panel: 步骤 1 中的图像 1,1
    • Lift the lever to unlock the case.
  2. Mac Pro First Generation Power Supply Unit Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 步骤 3 中的图像 1,3 Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 步骤 3 中的图像 2,3 Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 步骤 3 中的图像 3,3
    • The optical drive must be removed to access the power supply unit
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
    The lever on the back of the machine needs to remain open for the optical drive to be removed
    Markus - 回复
    My 3.1 optical drive bay is stuck. I pull and pull but I cannot remove it. Yes I could before and the lever remains open before pulling. :(
    mig - 回复
  4. Mac Pro First Generation Power Supply Unit Replacement, Unplugging the Disk Drive: 步骤 4 中的图像 1,2 Mac Pro First Generation Power Supply Unit Replacement, Unplugging the Disk Drive: 步骤 4 中的图像 2,2
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
  5. Mac Pro First Generation Power Supply Unit Replacement, Un-Mounting the Power Supply Unit: 步骤 5 中的图像 1,2 Mac Pro First Generation Power Supply Unit Replacement, Un-Mounting the Power Supply Unit: 步骤 5 中的图像 2,2
    • Remove the 4 marked 6-32 hex screws with a 2mm Phillips hex screwdriver.
    • There are a number of Phillips head screws underneath. These don't need to be removed to remove the power supply.
    • Note the different PSU for Mac Pro 1,1 through 3,1 versus Mac Pro 4,1 and 5,1.
  6. Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 步骤 6 中的图像 1,3 Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 步骤 6 中的图像 2,3 Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 步骤 6 中的图像 3,3
    • Be careful when pulling the power supply out, as it has several attached cables which don't have much slack.
    • Grip the handle on the left side of the power supply casing while gripping the right side of the power supply casing and pull upwards firmly to to take it out.
    This is not correct for the Mac Pro (Early 2008), a.k.a. MacPro3,1
    In the MacPro3,1, the power supply screws are 2.5mm hex, not T-10.
    Also, there is a cover plate behind the superdrive that has to be removed (2 phillips screws) to expose the power cable connections and those connectors must be detached before the power supply can be removed.
    Bernard - 回复
    My Mac Pro (Early 2008) had the cover plate over the connectors, but the 4 screws were 2.0mm hex rather than 2.5mm hex. Seems they didn't standardize on a single size.
    Thomas Emmerich - 回复
    my mac pro 4,1 (early 2009) also had the cover plate behind the superdrive. had to disconnect cable before pulling out psu.
    Tino - 回复
  7. Mac Pro First Generation Power Supply Unit Replacement, If power Supply only comes out a few Inches.: 步骤 7 中的图像 1,2 Mac Pro First Generation Power Supply Unit Replacement, If power Supply only comes out a few Inches.: 步骤 7 中的图像 2,2
    • For the Mac Pro (Early 2008/9), a.k.a. MacPro3,1 In the MacPro3,1, the power supply screws are 2.5mm hex, not T-10. Also, there is a cover plate behind the superdrive that has to be removed (2 phillips screws) to expose the power cable connections and those connectors must be detached and slid under fan before the power supply can be removed.
    Absolutly right.i've tried that and it works.I'm satisfied
    multirecord - 回复
    I have a Mac Pro 3.1 and I’m having problems in reassembling the power supply. It seems that the cables prevent the PSU to sit flush and to be screwed back in place. where should I tuck the cables? It seems unnecessary hard - therefore I must be doing something wrong.
    Riccardo - 回复
  8. Mac Pro First Generation Power Supply Unit Replacement, Disconnecting the Power Supply: 步骤 8 中的图像 1,2 Mac Pro First Generation Power Supply Unit Replacement, Disconnecting the Power Supply: 步骤 8 中的图像 2,2
    • Locate the four marked cables
    • Push down on the clip that is above each cable connector while firmly grasping each connector and pull each one back to remove each clip.
    In my early 2008 mac pro, the power supply cords (female side) were secured to the case with hooks & loop tape (velcro), and I had to carefully release these before I could grasp the clips to release the connectors.
    sunnyjono - 回复
    Hi, I’m having issues in reassembling the power supply. The cables won’t fold right and prevent the power supply to sit well at the bottom of the case (the side). Are there photos to show how the cables should fold, and where?
    Thanks!
    Riccardo - 回复
    Super. Merci. J'ai pu l'enlever facilement.
    louveaumarco - 回复
结论
76等其他人完成本指南。
Eric Kuhta
于10/12/14注册
1,201 声望
撰写一个指南
团队
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G24
4 名成员
创作了13篇指南
23条评论
15 min power on after off
Manish Kumar - 回复
Hi
Very difficult to find the exact size of the bit for the screwdriver. And it is very tight to unscrew one of the screws.
Maybe I had spoiled the head of the screw.
What is the solution?
Thank you in advance.
Michel
Michel - 回复
missing a very crucial step before step 6. if you don't remove the cover (where cd rom is) and unplug the PSU cable, you'll damage something.
for screws, 2.5mm didn't work for me, but i used a 3/32 hex with ball end, and at an angle, it will loosen screws.
Tino - 回复
Doesn't work for a micron. Step 6 is impossible. Can't get the power supply out of its place more than a few centimeters. The side closest to the backplate of the casing can't come up only some millimeters, while also the fixed!! power cord is a serious obstruction.
Moreover there are nowhere cover plates left, so this is not a comparable situation as described in step 7.
Hugo Walg - 回复
My last remark should be forgotten. The power cord has been connected to the Mac pro to give the impression that it's mounted fixedly to the power supply. But if you pull with very much force (an attempt of despair), it then again appears to be a 3-hole connector like is the case for common computers. If you don't know these systems, this is very treacherous.
Hugo Walg - 回复
But now for something completely different:
Is there somebody who can tell, how you get the power supply out of its case? I removed 9 screws (these are accessible from the outside) but the power supply doesn't come out of its frame. It remains hidden into the aluminum case, and nothing can be examined.
Hugo Walg - 回复
You are awesome. The instructions were so clear that I would post the difficulty as low to moderate. I took out the power supply, wrote down the info, ordered another, cleaned fans, power supply unit, interior, etc. , replaced the original power supply, and it runs quietly and better than ever. I now have a back-up, and have a clean machine and some dust bunnies I am fostering. Any interest to adopt the dust bunnies please contact www.bunnydust.de. That's a dumb joke and not an endorsement
MrBuxley
Neal Walker - 回复
Hoi fixed in aprox 35 minutes works perfect
Henry Keijzer - 回复
It was a bit difficult and I have newer mac pro but i did it. Rejoice. Anybody still having problem let me know and I’ll tell how in better detail.
Doug Boyne - 回复
The screws are thee worst part. Really awkward. I’ll come back later sometime to check if any in distress.
Doug Boyne - 回复
Mine is Generation 5.something. I would say it is easier than this one, now that I have done it. But 20 to 25 minutes yea sure if you are an Apple genius but to Joe in the street it is rocket science.
Doug Boyne - 回复
Awesome Dude, you are! Thank you very much!
Michael Reibel - 回复
Where can i get a MacPro 1.1 power supply in good working condition to replace my unit? APPLE PART NUMBER IS: 614-0383
riquivelarde - 回复
Hi Eric, Thanks for posting this. Im looking at replacing my early 2008 macpro power supply due to random restart issues. I’ve been told that the screws require torx not hex, and I see some folks saying that 2.5 mm hex didn’t work. If you or anyone else can clarify I’d really appreciate it.
Thanks -
Joe Hall - 回复
Seriously , To remove the 4 marked 6-32 hex screws was a pain!!!! TIP: I was almost trowing thetower when my wife suggested me to cut a little peace of rubber from an old rubber glove from the kitchen and use it as a cushion to tight the connection between the hole of the screw and the screwdriver. I must tell you all, I managed but it was not ease!!! :-)
rock - 回复
Ok I did it. Hope it works now. Took me about 40 minutes of non stop cursing. But I did it. Thanks for the instructions. I didn’t bother putting that one screw back in…
Nick - 回复
where can i get the power supply fan for my 2009 Mac Pro? Mine is not working well. Makes a terrible sound…..
3D Renders - 回复
I have a problem with my MAc pro 3.1 not always starts, (when it starts runs perfect) it seems the power supply, this is I’m here, nut I’m not sure that is the real propblm and I don’t want to waste money!
Gigi D'Amico - 回复
can we fix normal power supply in mac pro 1289 (normal pcs ) while its difficult to get the original here
AHMED355 - 回复
Fairly easy install. Hardest part was getting the cover plate behind the DVD drive back in place. My hands are too big to fit in there and it takes a very long screwdriver to reach.
My cable connectors were held in place by velcro. Found it much easier to remove the cover plate, unplug the connectors, then pull the power supply out.
glenthompson - 回复
I have reconnected all the cables correctly i hope, but my unit doesn't want to go all the way in. Izit the way the wires are bundled at the bottom of it? And how can i flatten it a bit so it doesn't for a heap at the bottom? It stick out about 5-8cm above the flush surface..
Gilbert Scheepers - 回复
mig - 回复
The PSU screw threads are partially coated with a very tough locking compound making them very stiff to remove. I removed this with a mixture of rubbing alcohol and light machine oil. Much easier to reinstall and not too worried about them coming loose in my lifetime😎
Like Timo above I found that none of the recommended bit sizes were a proper tight fit. Easy to strip the screw head. Another good reason to remove the locking compound.
phillipvictorbova - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 66
过去 30 天: 252
总计 81,087
