跳转到主内容
Mac Pro First Generation Hard Disk Drive (HDD) Replacement
你所需要的
  1. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Case Panel: 步骤 1 中的图像 1,1
    • Lift the lever to unlock the case.
  2. Mac Pro First Generation Hard Disk Drive (HDD) Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Locate the Hard Drive Bays: 步骤 3 中的图像 1,1
    • Locate the desired hard drive bay after opening the case .
    • This is usually the drive closest to the front of the case.
  4. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 步骤 4 中的图像 1,3 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 步骤 4 中的图像 2,3 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: 步骤 4 中的图像 3,3
    • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
    • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
  5. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 步骤 5 中的图像 1,3 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 步骤 5 中的图像 2,3 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: 步骤 5 中的图像 3,3
    • When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures.
    • Locate the four 6-32 type screws on the Hard Drive sled.
    • Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
结论
10等其他人完成本指南。
Charlie Franklin
于10/12/14注册
1,148 声望
撰写一个指南
团队
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G24
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 35
过去 30 天: 156
总计 22,079
