Lift the flap to put it in the unlocked position. The panel should separate from the case without force.
Then to remove the hard drives, pull them towards you with a bit of force.
Simply pull the DVD drive bracket towards you, just like with the hard drives. Force it gently.
On the fan bracket, there is something like a button. Press it to move the support to the left (see picture)
Then pull the graphics card towards you to take it out of the case
With a screwdriver, unscrew the two screws that hold the fan bracket to the board
Pull the fan towards you (to move it away from the case)
Behind the fan bracket, there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
Disconnect the 2 x 4 pin fan cables and the 1 x 2 pin speaker cable
Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
