当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
CAREFULLY lift the back of the screen and keyboard unit(the top of the computer) and GENTLY push the front left and right corners away from the bottom unit until a click is heard. Then, SLOWLY lift the top unit and remove the interconnect cable (the large somewhat brittle cable connecting the two halves) from its socket in the sisterboard.
这个步骤还没有翻译 帮忙翻译一下
Now, remove the long, flat HDA cable from the hard drive by pulling the white plastic piece directly out of the bottom of the hard drive. Be sure to do this CAREFULLY, as the flat cable can easily become disconnected from the plastic piece. Should this happen, pull the top and bottom of the piece away from each other and GENTLY re-insert the cable.
另外一个人完成了本指南。
