跳转到主内容
Mac Powerbook 140 Battery Replacement
你所需要的
  1. Mac Powerbook 140 Battery  Replacement, Aquire Battery: 步骤 1 中的图像 1,1
    • Begin by locating the correct type of battery. A simple internet search or a glance at Amazon.com should bring the right results. BE SURE THAT THE BATTERY IS COMPATIBLE WITH THE COMPUTER. Not doing so could result in injury.
  2. Mac Powerbook 140 Battery  Replacement, Remove Original Battery: 步骤 2 中的图像 1,1
    • Slide the battery panel ( or switch, depending on the battery) on the left side of the computer so the battery is in the "Unlocked" position. Pull the battery straight out. Put in the new battery and slide the panel/switch to the "Locked" position.
结论
It is not required, but I always find it useful to save the old battery, lest you need it later. Unless the battery is leaking, or poses some other health/safety issue(in which case dispose of it in the proper manner), store it in a battery-safe environment.
2等其他人完成本指南。
Jack
于10/23/15注册
810 声望
创作了3篇指南
1指南评论
I can’t find a replacement battery anywhere, they’re either out of stock or in another powerbook on ebay and those cost $80 with the chance that the battery in them is dead too.
BCG04 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,941
