简介
仅供前提条件。
你所需要的
即将完成!
如要重新组装设备,请按照倒序进行。
结论
如要重新组装设备,请按照倒序进行。
4等其他人完成本指南。
由衷感谢以下译者:
en zh
83%
ycwei982正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Like others, a T8 screw driver worked best for me on the 4 hard drive screws.
sorinjc - 回复
it is t8 not t9. you owe me a TR6 Torx Security bit :D
giammin - 回复
I found the 4 screws quite hard to remove and needed to use an 8mm spanner on the back of my T8 screwdriver to get them loose.
Reiner Friedel - 回复
Screws have loctite residue. I put a tiny drop of fresh blue (semi-permanent) on each screw before reinstalling.
Jon Scott - 回复
T9 was the right one for mine
Bill Pennock - 回复
T9 Torx from recommended barely allowed me to remove these screws. I had to press very strong them into screws, so that pressure and minimal adhesion made it possible to move something.
Vitalijs Ozornins - 回复
T8 was more appropriate for me !!!
afajner - 回复
The instructions at the top recommend a T9 but the link plops a TR9 into your basket. In any event, the T8 works better.
tom - 回复
T8 was also good for me. Mini was manufactured in 2016 October.
soul.tan - 回复
TR7 did the job.
Benni Piron - 回复
Is this a security screwdriver just like the TR6 Security Screwdriver?
Shubham Ojha - 回复
When i did the re-assembly as I was adding a drive to a pcie only mac, i didnt have any t8 screws (so used standard phllips onces which came with the sata kit but i struggled to make sure the wires were out of the way. I dont know if the configuration for mac minis with drive is slightly different but you need to be careful not to screw down any of the wires (i think for IR sensors).
Edward Chandler - 回复
Can anyone confirm a T8S (security) driver is needed for this, not a non-security T8?
Cornfritter - 回复
