简介
使用本指南来更换工作不正常的风扇。
你所需要的
倾斜mini,使底盖从外壳上脱落。
取下底盖,放置在一边。
I have a late 2012 Mac mini, but it must be an earlier version than this late 2012 Mac mini in this description, because removing the hard drive is much more complicated than described here. Please see this YouTube video if you have trouble removing your hard drive with these directions. https://www.youtube.com/watch?v=cvmuQIZP... There is a longer process you've got to go through. It can be done, it just takes much longer. (3-4 hours for me)
This applied to me as well. The iFixit article was good and lots of helpful information in the comments but my mini was different and required more dismantling. The video sandyfacebook posted was very helpful in taking me the rest of the way. https://www.youtube.com/watch?v=cvmuQIZP...
My HDD replacement procedure took 2 jours of research, one night sleeping on it and 30 minutes to perform…
卸下天线板附近,把风扇固定在逻辑板上的两颗11.3 mm T6 Torx螺丝。
Remove a third screw at the opposite end of the fan near the DRAM
Not necessary to remove that screw at that point to get the fan out. It is only a post at that point.
Remove it in step 14.
The fan has in fact, 3 screws that need to be removed before you can lift it out.
That screw is a post at that point. I removed it at step 14.
The 3rd screw needed a T5, for me.
All of mine have 3-T6 screws.
Kadah Coba - 回复
I can't, for the life of me, get the left screw out of the cowling. Had to pull both out together. Now having a very hard time getting the cowling back in to replace the fan.
I can’t remove the left screw to separate the fan to the cooler. Impossible to put back the fan and the cooler.
One of my fan screws don't come out, even though I keep trying to unscrew the screw. I tried a lot of things ranging from pulling the fan up to just trying to shake it out, please help me out with this
Only two screws as stated above need to be removed but as people have found out, the one in the cowling can bind into the post below it and it’s the post below that unscrews instead. So you end up with the screw+the post+the fan all together as one. That assembly can be worked out, and then with two pairs of pliers the post and screw can be separated.
The lower right T6 fan screw is a standoff (that also secures the logic board). This can be loosened and kept with the fan, or (since it is friction captured in a grommet on the fan), the fan can be lifted off, being careful not to dislodge the grommet.
Hi… Hi… Good. I have a query, I want to change my internal hard drive from my Mac Mini (mid) 2011, and my query is whether to remove the fan screws and other parts, which from what I was informed is the Torx T6 screwdriver. And my question is: to remove it I need a Torx T6 screwdriver with a hollow point or the Torx T6 with a flat tip will work for me. From what I have read, that the hollow point Torx are called Precision Torx or are identified with an "H" after the number in this case: "T6H". The same query is to remove the cover where the WiFi is, should I use a Torx T8 hollow point or does the flat point work for me? From now on I thank you get me out of this doubt, before doing something wrong. Thank you very much and greetings. Image (Augusto)
After having a look on YouTube at various methods I found it was not necessary to disconnect the fan or the antenna plate. I rotated the antenna plate out of the way and secured it with a piece of masking tape. I also found that I didn't have to move the logic board either. I lifted the HDD connector (gently) with a spludger . The original HDD came out easily once I managed to grip the plastic PCB cover (which isn't needed on the SSD) . Fitting the new SSD was easy using a masking tape 'handle' in the shape of an upside down 'T' . funnily enough the hardest part was getting the little plastic shroud on the left to sit nicely but even that was easy once I had used the masking tape 'handle' I'd used on the SSD. I always think the less you have to mess with the less chance of anything going wrong. Oh, and buy a antistatic wriststrap !
When reassembling, take care to not over-tighten the screw on the left of the photo, which goes into the cowling. If this is screwed-in tight, then it may cause problems the next time you disassemble the Mini. (This screw is screwed into a second screw - and when you remove it, you only want the topmost screw to come out)
将靠近RAM附近一侧的风扇从固定外壳的支架上提起。
Same for me, couldn't get it to move without feeling it was going to break so I just removed the screw.
Ditto re: standoff screw
Better to remove the 3rd bolt here, making it easier to remove the fan. It needs to be removed anyway in step 14.
I ended up removing the complete stand off post.
My whole fan connector just broke when reconnecting
将风扇提升的足够到的高度来将连接器分离。
小心的将风扇排线连接器从逻辑板的插座中拔出。
移除风扇。
You actually don't need to disconnect the fan. You can just let it hang on the side while working. I accidentally killed my connector trying to pry it loose. It's being held together now by some tape, after spending hours trying to reconnect it and figuring out pin outs.
Did it just as Nick suggested, hang the assembly to the side.
Agreed. It is much better to leave the fan connected. The only thing you actually need to disconnect is the hard drive.
ablack3 -
Absolutely. just dangle it.
110% agreed: you don’t have to remove the fan. Those wires are delicate, as is the connector. Just move it off to the side. Do the same for the antenna plate. The fewer connectors you touch, the fewer things you break!
These instructions are used as a prerequisite for many other repairs where the fan simply has to be removed in order to continue. (For example, fan replacement.) I would not recommend leaving the fan dangling from the board during a repair, as that’s a hazard all by itself. If you insist on leaving the fan connected, secure it to the chassis with some masking tape to make it a little less dangerous.
The fan has some slack cable on it. Once you have unscrewed the fan, you should see that the connecting cable is wrapped around two hooks. CAREFULLY move the cable around the hooks to free it. You can then move the fan to one side out of the way while you access the hard drive bay. On reassembly, thread the cable back around the hooks before screwing it back in.
Be careful to LIFT UP on the fan connector cable. Using a spudger tool helps here. I mistakenly thought that the connector would slide off the logic board and tried to remove the connector this way. I ended up lifting the connector off of the logic board, thus ruining my logic board and requiring a $350 logic board replacement at the genius bar. The second time I did a HD/SSD replacement, everything worked fine.
Yeah, I did the same thing by following someone elses "shortcut". Now I am going to shell out 289 for quad core i5 board, and a new fan BTW. . . . . . Oh well never a dull moment :) and it gets an upgrade as well!
That's probably the must tricky part of the replacement. I did the same thing, i just pull on my cables and the connector stays on the board. Tried many times to switch cables into but any order i try is not the good one.
The avoid this, now, when i want to pull out my fan, i just use a plate screwdriver and lift up the connector. That's work perfectly.
I screwed it too... Not reading carefully enough, I accidentally removed the whole socket from the board. This happened with the IR connector too. When re-assembling the parts, the socket wouldn't stick to the board, now I know why. I don't want to buy a new logic board, because I can't afford one, so I'm trying to find someone to solder it. Seems hard to find someone able to repair logic boards these days. Hope I'll be successful, otherwise this is an expensive upgrade to my mac...
Don't remove it with your fingers, use a tool for that. And underneath the wires!
Followed all the instructions, everything went well, but now my mini fan won't turn off. It starts as soon as I boot up. I've tried every fan control software out there, and nothing works; the fan just constantly runs. I was very careful when I disconnected/reconnected the fan cable, and it looks fine. What else can I do?
Ben Dunkle - 回复
The problem is most likely a disconnected or damaged temperature sensor, I had this problem when reassembling a 2007 Mac mini. It can't read the temperature, so assumes the worst and sets the fan to maximum.
For heavens sake please DON'T remove the fan. It's really really hard to reconnect it properly. And besides that you don't have to remove the Logic Board for just changing the HDD.
It’s very easy to reconnect if you know how. Position the connector over the socket as shown in the photo, and press it down. As long as it’s not upside-down or anything, you’re done in 5 seconds.
Does anyone know how to solve the full RPM fan issue? My computer guy couldn't solve with fan control software
I removed the fan and everything worked fine, but it’s good to know that it’s a “push-down“ connector, took me some time to relize that, all I needed to do was to press down the connector over the pins, see the picture for more details.
Jan Igerud - 回复
The direction you “ gently pull” to remove the connector is all important. You have to pull upwards, vertically away from the board. If you pull more downwards parallel to the board, you may end up wrecking the connector by pulling the wires out of it as I did. Fortunately the socket was okay so it was just a case of buying a $10 replacement fan (complete with new connector).
DAGNABBIT! Broke it! Now I have a fan blowing on the open case while it’s operating. What can I use as a shield for dust but still allow for airflow?
OMG, please change this instruction to NOT remove the fan. What a nightmare trying to reseat it.
You need to position it over the socket as shown and press straight down. If it takes you more than 5-10 seconds, something’s wrong.
really wish i would have seen these comments before I ripped out the fan from the logic board.
I missed the word UP and instead pulled the wires straight out, which ended up with me holding the wires but leaving the plug behind in the socket. I just ordered a replacement fan from ebay, since ifixit is out of the one in the correct amperage for this unit.
I then edited the guide to capitalize and bold the word “UP” and hopefully that saves somebody else a bit of hassle.
Any step with a lot of comments is one people have trouble with. It might be useful if ifixit were to make it more obvious we should read the comments, at least for those that have a lot of them. It would save a lot of people a lot of hassle.
Just for emphasis on this point, I did exactly that - I ripped the fan connector right off of a perfectly good logic board. I used a plastic pry tool and was attempting to follow OWC video for replacing the drive. So beware! Trust me, it is not that hard to rip this thing off the board.
DO NOT REMOVE THE FAN.
Put it to one side.
Here’s a video showing how this is done: https://youtu.be/KlR-RWtqzis
32等其他人完成本指南。
由衷感谢以下译者:
66%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
step 3 should have note to remove 3 ea. screws ... the screw on the left bottom on the picture is not shown ... it is obvious when you look at the fan you recieve ... connector came out very easy, just pull up (easily) ... took less than 15 minutes on my i7 server mini, mid 2011 model
DiSH
This took a lot of force on my Mac mini. A lot.
nh3 - 回复
I agree. It took a crap ton of force from my thumbs to twist the bottom off.
sleeve -
I accidentally broke the little things that hold the cover to the case. Is there a cheap replacement to the cover? Those clips are held onto it very weakly.
Jacob Halton - 回复
Don't just use your thumbs... Use your whole palm to twist it, with maybe a thumb in one of the recesses, applying slight downward pressure.
markbart - 回复
Wish I would have read this comment before I did it!
I found that what markbart said works best. one palm one thumb (and my knees) My thumbs would do it. It was a bit at a time.
Same difficulty getting it back on.
Would be handy if this (difficulty) was mentioned in the guide
Also would be nice to mention the safe practice of pressing the power button for a few seconds after disconnected to rid the system of any residual power, working in a clean static free environment & they say on the crucial website to touch a metal surface of the machine before touching the RAM
Nancy -
I think it depends, I have seen some that are very difficult to open and some super easy. But I see them everyday. I wish there was a tool that fit in the holes.
Justin Weathersbee - 回复
When seating the bottom RAM chip you may have to apply a little extra side force to get it to seat properly. I put in the new RAM and just got a beeping sound upon starting. I then put the old RAM back in and got the same result.
Here is the solution I found on the Apple discussion board.
"Take a small flat head screwdriver and after you put the memory in slot 0, put the screwdriver between the top of the mac mini and the memory then turn the screwdriver a little to exert pressure on the memory into the slot. Do it on both sides of the memory."
This worked for me.
littlemas2 - 回复
I remember this when I was changing my memory ... I realized (after opening) that more you push, more force it take to open the cover. As you push down you force the cover "to rub" the casing and possibly other things inside. If you "lightly" hold the cover it comes right off ... Remember: less is more! :-)
Have fun!
Radek - 回复
We found it hard to use the thumbs but if you put the casing on a carpet and one person is holding the case while the other is using his palm of one hand to turn the cover it comes off quite smoothly and without much downward pressure.
Alexander - 回复
If you're upgrading to an SSD, before you even take this first step, I'd recommend putting the SSD into an external drive case, using USB and format the SSD first before trying to swap your existing hard drive or implementing a fusion drive. The external drive case will come in handy later so you can use the old drive as extra storage anyhow.
Once that SSD is internal, the Mac errors out during the formatting process. Once it was formatted externally, then installed inside the Mac again, there was no problem.
Orange Girl - 回复
The first time I did this it hurt! The second time my mac mini 2012 had been running so was warm. VERY EASY WHEN WARM. No fun when cool!
Nancy - 回复
Forget about those 2 circle indents. if you consider the 2 marked dots (open and close) as position 12 o’clock, place your thumbs at 11 and 1 o’clock on the outer rim of the cover and rotate from that position.
juicer52 - 回复
No way was I getting the back off. So I made a tool. Took a large wrench longer than the Mac mini. Superglued 2 rubber feet on the wrench at the same location as the thumb indents. Put the Mac on the ground, between my knees and used my body weight to turn the cover. Worked like a charm.
Mark - 回复
Hey dos anyone know if that can lead to the 3 beep RAM problem? I just got a Mac mini witch has the 3 Beeps when started. its not the RAMs them self because thy work in other Macs so if this could lead to thee 3 Beep problem it would make it more Ez because I don't have to Re solder the RAM Port. (This Mac mini was Running over 10 years and after it got turned of for the first Tim it started to have this problem) I think because of Over heading.
Arvid000 - 回复
