跳转到主内容
MSI VR601 WiFi card Replacement
你所需要的
  1. MSI VR601 WiFi card Replacement, Open the back cover: 步骤 1 中的图像 1,2 MSI VR601 WiFi card Replacement, Open the back cover: 步骤 1 中的图像 2,2
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: 步骤 2 中的图像 1,2 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: 步骤 2 中的图像 2,2
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: 步骤 3 中的图像 1,1
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
结论
Geir Ove Andersen
于06/06/22注册
7,815 声望
创作了5篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 17
总计 242
