跳转到主内容
MSI PE70 6QE-035US speaker Replacement
你所需要的
  1. MSI PE70 6QE-035US speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US speaker Replacement: 步骤 2 中的图像 1,2 MSI PE70 6QE-035US speaker Replacement: 步骤 2 中的图像 2,2
    • After you remove the back panel, you should now see the 3 speakers.
    • We will start with the bottom most speaker.
  3. MSI PE70 6QE-035US speaker Replacement: 步骤 3 中的图像 1,2 MSI PE70 6QE-035US speaker Replacement: 步骤 3 中的图像 2,2
    • Using the ifixit opening tool, remove the speaker by gently unplugging its cord from the motherboard. Be sure to unplug the cord in the direction shown by the arrow.
    • After the cord has been unplugged, the speaker should now be able to be lifted out.
  4. MSI PE70 6QE-035US speaker Replacement: 步骤 4 中的图像 1,3 MSI PE70 6QE-035US speaker Replacement: 步骤 4 中的图像 2,3 MSI PE70 6QE-035US speaker Replacement: 步骤 4 中的图像 3,3
    • These two speakers will be taken out together because they are held in by the same cord.
    • Once you have unplugged the cord, both speakers should be able to be lifted out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 66
