跳转到主内容
MSI MS-1782 Wi-Fi Card Replacement
你所需要的
  1. MSI MS-1782 Wi-Fi Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 MSI MS-1782 Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 MSI MS-1782 Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 1,3 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 2,3 MSI MS-1782 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 3,3
    • Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
  4. MSI MS-1782 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 MSI MS-1782 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
  5. MSI MS-1782 Wi-Fi Card Replacement: 步骤 5 中的图像 1,2 MSI MS-1782 Wi-Fi Card Replacement: 步骤 5 中的图像 2,2
    • Remove the Wi-Fi card at its angle.
结论
To reassemble your device, follow these instructions in reverse order and make sure you put the antenna wires back in the correct order.
A'kia
于03/08/23注册
193 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 113
