跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的MSI Katana 15 B13V,应参考我们的维修指南
    • The first step is to take your screwdriver and remove all 13 screws keeping the back panel in place. After every screw is removed and placed in or on something where you won't lose it, carefully life up the back panel off of the laptop.
    • Gently brush each blade of the fans with your toothbrush or soft cloth. If your cleaning tool starts to get too dirty, wipe off any dust with a dry cloth or grab a new, clean cloth or toothbrush.
    • Carefully place the back panel onto the laptop and gently press down along the edges until you hear a click. One the panel is secure and not moving around, put every screw back into place and screw them in.
    • Finally, after the laptop is put back together, turn it on and check if it is still functional.
Tudor L
于05/09/24注册
109 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 33
过去 30 天: 123
总计 1,378
