跳转到主内容
MSI GT75VR 7RF Titan Pro RAM Card Replacement
你所需要的
  1. MSI GT75VR 7RF Titan Pro RAM Card Replacement, RAM Card: 步骤 1 中的图像 1,1
    • Unscrew each of the four screws using the Phillips #0 head on the back of the laptop case. The screws are 0.5 inches in length.
  2. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 步骤 2 中的图像 1,2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: 步骤 2 中的图像 2,2
    • Pop the back cover off of the laptop using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery cable.
  4. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 步骤 4 中的图像 1,2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: 步骤 4 中的图像 2,2
    • Pry the battery pack up with the black nylon spudger.
  5. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 步骤 5 中的图像 1,1
    • Pop the metal tabs on each side of the RAM using the black nylon spudger.
  6. MSI GT75VR 7RF Titan Pro RAM Card Replacement: 步骤 6 中的图像 1,1
    • Lift and remove RAM card by hand. Replace each RAM card and test them individually. If your computer encounters a RAM error with only one card inserted, you can confirm that card is corrupted.
结论
Jack Crumpton
于08/31/18注册
241 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 649
