跳转到主内容
MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement
你所需要的
  1. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: 步骤 1 中的图像 1,3 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: 步骤 1 中的图像 2,3 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement, CPU/GPU Chip: 步骤 1 中的图像 3,3
    • Remove the four screws from the rear laptop cover using the Phillips #0 screwdriver. The screws are 0.5 inches long.
    • Use the black nylon spudger to pry the cover off the laptop.
  2. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 步骤 2 中的图像 1,3 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 步骤 2 中的图像 2,3 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 步骤 2 中的图像 3,3
    • Unplug the battery plug from the unit. Lift the battery out of the housing by prying it from the adhesive using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 步骤 3 中的图像 1,1
    • Remove the screws using the Phillips #0 screwdriver. Disconnect the left side fan from the unit as shown. The screws are 0.25 inches long.
  4. MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 步骤 4 中的图像 1,2 MSI GT75VR 7RF Titan Pro CPU/GPU Chip Replacement: 步骤 4 中的图像 2,2
    • Unscrew the CPU cooling plate using the Phillips #0 screwdriver. Lift the cooling pipes away from the unit. Screws are 0.15625 inches long.
    • Unscrew both standoff nuts from the chip using the Phillips #0 screwdriver. Then lift and remove the unit from the laptop.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 1,339
