简介
If your screen is malfunctioning, showing a blue screen then you should follow these steps on our guide to help replace your screen. You will also need a Jimmy and a screw driver to replace the screen.
你所需要的
Remove the rubber guards covering the two 3mm screws on the bottom of the screen and remove the screws with a Phillips #0 screwdriver.
即将完成!
结论
另外一个人完成了本指南。
