跳转到主内容
MSI GT62VR 6RD Dominator Battery Replacement
你所需要的
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: 步骤 1 中的图像 1,2 MSI GT62VR 6RD Dominator Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: 步骤 2 中的图像 1,2 MSI GT62VR 6RD Dominator Battery Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: 步骤 3 中的图像 1,3 MSI GT62VR 6RD Dominator Battery Replacement: 步骤 3 中的图像 2,3 MSI GT62VR 6RD Dominator Battery Replacement: 步骤 3 中的图像 3,3
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
结论
Rebekah Johnson
于09/18/18注册
147 声望
撰写一个指南
一条评论
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,953
