跳转到主内容
MSI GS70 Hard Drive Replacement
你所需要的
  1. MSI GS70 Hard Drive Replacement, Remove the Backplate: 步骤 1 中的图像 1,2 MSI GS70 Hard Drive Replacement, Remove the Backplate: 步骤 1 中的图像 2,2
    • Using your JIS #1, locate and remove all screws from the backplate.
    • When all the screws are removed, proceed to remove the backplate. The hard drive will be located right next to the battery.
  2. MSI GS70 Hard Drive Replacement, Remove the Hard Drive Spacer: 步骤 2 中的图像 1,2 MSI GS70 Hard Drive Replacement, Remove the Hard Drive Spacer: 步骤 2 中的图像 2,2
    • Locate the black rubber spacer
    • Remove the spacer by gently pulling the flap
  3. MSI GS70 Hard Drive Replacement, Disconnect your Hard Drive: 步骤 3 中的图像 1,1
    • With two hands slide the Hard Drive to the left.
  4. MSI GS70 Hard Drive Replacement, Remove the Hard Drive: 步骤 4 中的图像 1,2 MSI GS70 Hard Drive Replacement, Remove the Hard Drive: 步骤 4 中的图像 2,2
    • Carfully lift up the Hard Drive using your Spudger.
    • Next, pull up your hard drive from the battery end and proceed to remove the hard drive
结论
11等其他人完成本指南。
2条评论
The screws on my machine were Philips not torx don't know if it is different or has changed at all but all internal and external were Phillips
rambo33hockey - 回复
bonjour
comment accéder au disque dur msata sur le msi gs 70
Vivabzh côtes d'armors - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 27
总计 16,116
