跳转到主内容
MSI GS70 Battery Replacement
你所需要的
  1. MSI GS70 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that the laptop is turned off before starting.
    • Place laptop with the bottom plate facing up.
  2. MSI GS70 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove all screws using the JIS #1 screwdriver.
    2 more screws right in the middle not marked in the pic. remember to get the one under the warranty sticker
    Dave D - 回复
  3. MSI GS70 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the back plate.
    • Locate the battery.
  4. MSI GS70 Battery Replacement: 步骤 4 中的图像 1,1
    • Locate the foil connector above the battery.
  5. MSI GS70 Battery Replacement: 步骤 5 中的图像 1,1
    • Flip up both black clips with your spudger.
  6. MSI GS70 Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the foil connector by pulling on the blue tabs.
  7. MSI GS70 Battery Replacement: 步骤 7 中的图像 1,1
    • After the foil connector is removed you will see an 8 pin connector.
    • Disconnect the 8 Pin connector.
  8. MSI GS70 Battery Replacement: 步骤 8 中的图像 1,1
    • Lift the battery and remove.
结论
10等其他人完成本指南。
3条评论
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - 回复
Which battery model should I buy?
slackware2007 - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 58
总计 8,936
