跳转到主内容
MSI GS63VR 6RF Stealth Pro Hard Drive Replacement
你所需要的
  1. MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Turn off the laptop before proceeding.
    • Unscrew the 15 screws on the bottom panel using a Phillips #00 screwdriver.
    • Pry open the back cover with a plastic prying tool.
    • Unplug the battery cable from the motherboard to prevent a ground fault. Either use your hand or a pair of tweezers to unplug the battery cable.
    • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
  2. MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: 步骤 2 中的图像 1,3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: 步骤 2 中的图像 2,3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Disconnect the SATA cables from the motherboard using a plastic spudger.
    • Gently pull out the SATA cables out of the ports.
    • Grab the auburn color cable and lift up the hard drive. Slide out the hard drive while holding onto the cable.
    • Cables are fragile. Do not apply excessive force.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 3,156
