跳转到主内容
MSI GS63VR 6RF Stealth Pro Battery Replacement
你所需要的
  1. MSI GS63VR 6RF Stealth Pro Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Phillips screwdriver to remove the 15 screws securing the back cover.
    • Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
    • Do not insert the opening too too far into the back edge (with "Stealth" written on it), or you may damage the power LED.
    • The back cover is secured with clips. Too much pressure from the spudger can break the clips, but some flex is not dangerous.
    • Remove the back cover.
  2. MSI GS63VR 6RF Stealth Pro Battery Replacement: 步骤 2 中的图像 1,1
    • Disconnect the battery by carefully pulling its connector towards the battery.
    • Pull parallel to the battery, not straight up.
  3. MSI GS63VR 6RF Stealth Pro Battery Replacement: 步骤 3 中的图像 1,2 MSI GS63VR 6RF Stealth Pro Battery Replacement: 步骤 3 中的图像 2,2
    • The battery is attached to the laptop with a strong adhesive.
    • Lift the battery from laptop.
    • Be careful not to bend the or puncture the battery, as that may cause a fire hazard.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 30
总计 6,598
