跳转到主内容
MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement
你所需要的
  1. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: 步骤 2 中的图像 1,1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: 步骤 3 中的图像 1,2 MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Pull the back panel off.
  5. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: 步骤 5 中的图像 1,1
    • Notice the L-shaped battery in the lower right corner of the opened laptop.
    • Disconnect the battery from the slot it is connected to. You'll need to push on the sides of the clip and pull.
  6. MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: 步骤 6 中的图像 1,2 MSI GS60 Ghost Pro 4K Gold Edition Battery Replacement: 步骤 6 中的图像 2,2
    • Lift up the battery with your fingers and remove it from the laptop.
    • Place the battery away from the laptop in a safe spot and insert your new battery by hooking it up to the slot you previously disconnected the old battery from.
结论
另外一个人完成了本指南。
Stephen Felix
于10/20/17注册
207 声望
创作了2篇指南
团队
UMass Dartmouth, Team S2-G2, Julie Fall 2017 UMass Dartmouth, Team S2-G2, Julie Fall 2017 的会员
UMASSD-JULIE-F17S2G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 1,047
