跳转到主内容
MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement
你所需要的
  1. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Remove the eleven 5mm screws with a Phillips #1 screwdriver.
    • Remove the four 2.5mm screws with a Phillips #1 screwdriver.
  2. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom plate from the laptop. Using a prying tool to slide between the bottom plate and chassis will result in easier removal.
  3. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the four 2.5mm screws using a Phillips #1 bit.
  4. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Carefully pry the screen assembly from the chassis on both sides. Use caution as the cable to the screen is located on the right bracket.
  5. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 5 中的图像 1,2 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Lay the components out as shown.
    • The rightmost of the two cable connections is located under sticky tape. Remove the tape to access it and unseat from the connection.
    • The other connection is removed by gently pulling up on the black grip tape.
  6. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 6 中的图像 1,2 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Gently feed both connections under the red, white, and yellow cables from the fan.
    • Note that both cables will meet and form a singular cable.
  7. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 7 中的图像 1,2 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Gently lift up on the back of the fan and remove the routed cable.
  8. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 8 中的图像 1,3 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 8 中的图像 2,3 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Using a prying tool, find the seam where the two pieces of screen meet and begin separating them.
    • Use caution, as there is glue and snapping clips holding them together.
    • Work around the perimeter, separating the pieces with the prying tool as you go.
  9. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Locate the metal bracket the cable is woven through.
    • Unweave the cable from the bracket. This will give you extra length to work with the screen.
  10. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Remove two 2.5mm screws with a Phillips #1 screwdriver.
  11. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 11 中的图像 1,2 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the screen.
    • Gently remove the yellow tape and then remove the connector.
  12. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: 步骤 12 中的图像 1,1
    • The defective screen is now completely removed and ready to be replaced.
结论
2等其他人完成本指南。
Coty Mast
于11/10/18注册
259 声望
撰写一个指南
团队
IUPUI, Team S1-G1, Wilson Fall 2018 IUPUI, Team S1-G1, Wilson Fall 2018 的会员
IUPUI-WILSON-F18S1G1
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 1,874
