跳转到主内容
MSI GP62MVR 6RF Leopard Pro Speakers Replacement
你所需要的
  1. MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Bottom Cover: 步骤 1 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 步骤 2 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 步骤 2 中的图像 2,2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Speakers: 步骤 4 中的图像 1,1
    • Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
  5. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 步骤 5 中的图像 1,1
    • On the front panel near the right speaker, there is a connection from the motherboard to the speakers.
    • Detach the white and black wiring from the clip.
  6. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: 步骤 6 中的图像 1,1
    • Peel back the electrical tape holding the speaker wire in place.
    • Remove the speakers from the front panel, pulling upward.
    • Note that the screws holding the two speakers down were already removed during the bottom cover removal.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 324
