跳转到主内容
MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement
你所需要的
  1. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,2
    • Using the Jimmy tool, pry the front cover off at the seam.
    • The Jimmy tool is the utensil in the first picture in the user's hand.
  2. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 步骤 2 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the four 2 mm screws on the bottom and top corners of the screen using a Phillips #0 screwdriver.
  3. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Using the Jimmy, pry off the unscrewed LCD display.
    • Make sure the black adhesive is out of the way.
    • Don't pull the screen completely off, as the screen will still be attached.
  4. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 步骤 4 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the ribbon cable by pulling on the bar code tab.
结论
另外一个人完成了本指南。
3指南评论
Hey Jordan, when reassembling the front cover (which in my case, a GP63 Leopard 8RE, is glued at the bottom) what type of glue should be used? Thanks
Jaime Blasco - 回复
Hi Jaime, two part expoxy (Alraldite) glue should work, otherwise 3M double-sided adhesive tape would work as well.
Jordan Buck -
Hi Jordan,
If the screen is damaged due to the cover itself being bent, do you have any advice?
Thanks
Ainsley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 1,795
