跳转到主内容
MSI GP62MVR 6RF Leopard Pro Battery Replacement
你所需要的
  1. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Battery Replacement: 步骤 2 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Battery Replacement: 步骤 2 中的图像 2,2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: 步骤 4 中的图像 1,3 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: 步骤 4 中的图像 2,3 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
    • Remove the battery from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 25
总计 1,198
