跳转到主内容
MSI GE72 6QF Apache Pro SSD Replacement
你所需要的
  1. MSI GE72 6QF Apache Pro SSD Replacement, Battery: 步骤 1 中的图像 1,2 MSI GE72 6QF Apache Pro SSD Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro SSD Replacement: 步骤 2 中的图像 1,1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro SSD Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro SSD Replacement: 步骤 4 中的图像 1,2 MSI GE72 6QF Apache Pro SSD Replacement: 步骤 4 中的图像 2,2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro SSD Replacement: 步骤 5 中的图像 1,2 MSI GE72 6QF Apache Pro SSD Replacement: 步骤 5 中的图像 2,2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro SSD Replacement: 步骤 6 中的图像 1,2 MSI GE72 6QF Apache Pro SSD Replacement: 步骤 6 中的图像 2,2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro SSD Replacement, SSD: 步骤 7 中的图像 1,2 MSI GE72 6QF Apache Pro SSD Replacement, SSD: 步骤 7 中的图像 2,2
    • Remove the single 5.5mm Phillips #1 screw attaching the SSD to the laptop.
  8. MSI GE72 6QF Apache Pro SSD Replacement: 步骤 8 中的图像 1,2 MSI GE72 6QF Apache Pro SSD Replacement: 步骤 8 中的图像 2,2
    • Pull out the SSD by gently wiggling it from side to side until it comes out.
    • If the old SSD you removed contains the operating system, then the new SSD must also contain an operating system.
结论
7等其他人完成本指南。
Tanmay Kumar
于04/17/17注册
461 声望
创作了4篇指南
团队
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 35
总计 8,318
