跳转到主内容
MSI GE72 6QF Apache Pro RAM Replacement
你所需要的
  1. MSI GE72 6QF Apache Pro RAM Replacement, Battery: 步骤 1 中的图像 1,2 MSI GE72 6QF Apache Pro RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro RAM Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro RAM Replacement: 步骤 4 中的图像 1,2 MSI GE72 6QF Apache Pro RAM Replacement: 步骤 4 中的图像 2,2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro RAM Replacement: 步骤 5 中的图像 1,2 MSI GE72 6QF Apache Pro RAM Replacement: 步骤 5 中的图像 2,2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro RAM Replacement: 步骤 6 中的图像 1,2 MSI GE72 6QF Apache Pro RAM Replacement: 步骤 6 中的图像 2,2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro RAM Replacement, RAM: 步骤 7 中的图像 1,2 MSI GE72 6QF Apache Pro RAM Replacement, RAM: 步骤 7 中的图像 2,2
    • When you open the back cover, the RAM will be located as shown in the picture.
  8. MSI GE72 6QF Apache Pro RAM Replacement: 步骤 8 中的图像 1,3 MSI GE72 6QF Apache Pro RAM Replacement: 步骤 8 中的图像 2,3 MSI GE72 6QF Apache Pro RAM Replacement: 步骤 8 中的图像 3,3
    • Press the hinges on the sides of the RAM chip as shown in the picture, in order to unlock it.
    • Carefully, slide it out at a 45 degree angle.
    • Don't press on the hinges too hard.
    • Be careful about the angle at which you're sliding out the chip.
  9. MSI GE72 6QF Apache Pro RAM Replacement: 步骤 9 中的图像 1,3 MSI GE72 6QF Apache Pro RAM Replacement: 步骤 9 中的图像 2,3 MSI GE72 6QF Apache Pro RAM Replacement: 步骤 9 中的图像 3,3
    • Similarly, press on the hinges on the sides of the other RAM chip, in order to unlock it.
    • Some laptop models might not come with two RAM chips, so if that is your case, you can skip this step.
结论
另外一个人完成了本指南。
Tanmay Kumar
于04/17/17注册
461 声望
创作了4篇指南
团队
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G4
4 名成员
创作了8篇指南
1指南评论
Can you put more ram in this laptop like 32gb?
Can you put another ssd?
nojus.zibikas - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 31
总计 5,130
