跳转到主内容
MSI GE72 6QF Apache Pro Optical Drive Replacement
你所需要的
  1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: 步骤 1 中的图像 1,2 MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Optical Drive Replacement: 步骤 4 中的图像 1,2 MSI GE72 6QF Apache Pro Optical Drive Replacement: 步骤 4 中的图像 2,2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Optical Drive Replacement: 步骤 5 中的图像 1,2 MSI GE72 6QF Apache Pro Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Optical Drive Replacement: 步骤 6 中的图像 1,2 MSI GE72 6QF Apache Pro Optical Drive Replacement: 步骤 6 中的图像 2,2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: 步骤 7 中的图像 1,3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: 步骤 7 中的图像 2,3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: 步骤 7 中的图像 3,3
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
结论
另外一个人完成了本指南。
2条评论
Why do you have to remove the battery first?
Kevin - 回复
So you don’t have power running through it while working on it.
croberts1290 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,438
