跳转到主内容
MSI GE72 6QF Apache Pro Hard Drive Replacement
你所需要的
  1. MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 4 中的图像 1,2 MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 5 中的图像 1,2 MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 6 中的图像 1,2 MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,2 MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Remove the two 5.5mm screws with the Phillips #1 screwdriver.
  8. MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 8 中的图像 1,2 MSI GE72 6QF Apache Pro Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Gently pull out the hard drive by wiggling it from right to left with your hands until it is removed.
结论
6等其他人完成本指南。
Tanmay Kumar
于04/17/17注册
458 声望
创作了4篇指南
团队
Cal Poly, Team S14-G4, Banghart Spring 2017 Cal Poly, Team S14-G4, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G4
4 名成员
创作了8篇指南
一条评论
I have just bought an MSI GP72VR Laptop and I screwed up and got the model with only one drive, an SSD. It nagged at me that I didn't get the one with 2 drives. Well I happen to build my own desktops and had a spare 500GB Mushkin SSD hanging around and decided, what the heck. I came here and couldn't find the exact model but this is identical for what I want. I have never seen an access like this where you have to remove 19 screws. So I am very happy that this is on iFixit. I removed the screws and couldn't get the bottom removed as shown, I had to go to the other side and then it came off fairly easily. I used a butter knife for the initial pry and that worked well. They had sent the disk holder with the computer so I had no problem installing and I just set it up in Disk Manager. Tanmay, thank you very much for the assist, it is appreciated.
adard745 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 7,768
