跳转到主内容
MSI GE70 2PE Apache Pro Keyboard Replacement
你所需要的
  1. MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Insert iFixit opening tool as shown in the picture to pry up on the keyboard guard.
    • Remove the keyboard guard.
  2. MSI GE70 2PE Apache Pro Keyboard Replacement: 步骤 2 中的图像 1,3 MSI GE70 2PE Apache Pro Keyboard Replacement: 步骤 2 中的图像 2,3 MSI GE70 2PE Apache Pro Keyboard Replacement: 步骤 2 中的图像 3,3
    • Insert the iFixit tool under the plastic screw cover.
    • Grab the plastic part with your hand and lift it off the casing.
    • Remove the plastic part to reveal the screws holding the keyboard in place.
  3. MSI GE70 2PE Apache Pro Keyboard Replacement: 步骤 3 中的图像 1,3 MSI GE70 2PE Apache Pro Keyboard Replacement: 步骤 3 中的图像 2,3 MSI GE70 2PE Apache Pro Keyboard Replacement: 步骤 3 中的图像 3,3
    • Unscrew the five screws located at the top of the keyboard.
    • Use the opening tool to lift the keyboard from its position
    • Be mindful of the ribbon cables when lifting the keyboard from the palmrest.
结论
2等其他人完成本指南。
2指南评论
What about step 4 detaching the ribbon cable?
russell89000 - 回复
yes missing the part of the 2 ribbon cables, one of them (the lighting) is not reachable like this..
you have to take out the battery, and then remove the back cover to reach the ribbon for the lighting
Kim Van Hoeck - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 46
总计 4,229
