跳转到主内容
MSI GE62 Apache Pro 004 Web Camera Replacement
你所需要的
  1. MSI GE62 Apache Pro 004 Web Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 2 中的图像 1,2 MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 3 中的图像 1,3 MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 3 中的图像 2,3 MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 3 中的图像 3,3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Web Camera Replacement, Web Camera: 步骤 4 中的图像 1,1
    • Flip over the laptop and open it.
  5. MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 5 中的图像 1,3 MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 5 中的图像 2,3 MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 5 中的图像 3,3
    • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
  6. MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 6 中的图像 1,2 MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 6 中的图像 2,2
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 7 中的图像 1,2 MSI GE62 Apache Pro 004 Web Camera Replacement: 步骤 7 中的图像 2,2
    • Locate the WebCam on the middle of the device.
    • Slide a metal opener tool to remove the Webcam
结论
Majid Al Hashmi
于02/13/18注册
283 声望
创作了2篇指南
团队
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 835
