跳转到主内容
MSI GE62 Apache Pro 004 Screen Replacement
你所需要的
  1. MSI GE62 Apache Pro 004 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Screen Replacement: 步骤 2 中的图像 1,2 MSI GE62 Apache Pro 004 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Screen Replacement: 步骤 3 中的图像 1,3 MSI GE62 Apache Pro 004 Screen Replacement: 步骤 3 中的图像 2,3 MSI GE62 Apache Pro 004 Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Screen Replacement, Screen: 步骤 4 中的图像 1,2 MSI GE62 Apache Pro 004 Screen Replacement, Screen: 步骤 4 中的图像 2,2
    • Open the laptop up as if you were going to use it.
    • Wedge a spudger in between the screen bezel and work it around to separate it.
  5. MSI GE62 Apache Pro 004 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the screws holding in the screen at the corners with a PH1 screwdriver.
    • Be very careful as the screen may tilt forward so make sure your hand is right is on the screen when the screw comes off.
  6. MSI GE62 Apache Pro 004 Screen Replacement: 步骤 6 中的图像 1,3 MSI GE62 Apache Pro 004 Screen Replacement: 步骤 6 中的图像 2,3 MSI GE62 Apache Pro 004 Screen Replacement: 步骤 6 中的图像 3,3
    • Remove the bezel from the screen.
    • Remove the two screws located at the bottom of the screen using the PH1 screwdriver.
结论
Samer Soukieh
于02/19/18注册
209 声望
撰写一个指南
团队
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,102
