跳转到主内容
MSI GE62 Apache Pro 004 Motherboard Replacement
你所需要的
  1. MSI GE62 Apache Pro 004 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Motherboard Replacement: 步骤 2 中的图像 1,2 MSI GE62 Apache Pro 004 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Motherboard Replacement: 步骤 3 中的图像 1,3 MSI GE62 Apache Pro 004 Motherboard Replacement: 步骤 3 中的图像 2,3 MSI GE62 Apache Pro 004 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  5. MSI GE62 Apache Pro 004 Motherboard Replacement: 步骤 5 中的图像 1,3 MSI GE62 Apache Pro 004 Motherboard Replacement: 步骤 5 中的图像 2,3 MSI GE62 Apache Pro 004 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
结论
Alexander
于02/19/18注册
86 声望
撰写一个指南
团队
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G5
4 名成员
创作了5篇指南
一条评论
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
rahim dargahi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 20
总计 1,979
