跳转到主内容
MSI GE62 Apache Pro 004 Battery Replacement
你所需要的
  1. MSI GE62 Apache Pro 004 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Battery Replacement: 步骤 2 中的图像 1,2 MSI GE62 Apache Pro 004 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Battery Replacement: 步骤 3 中的图像 1,3 MSI GE62 Apache Pro 004 Battery Replacement: 步骤 3 中的图像 2,3 MSI GE62 Apache Pro 004 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
结论
6等其他人完成本指南。
Arian Arana
于02/13/18注册
187 声望
撰写一个指南
团队
USF Tampa, Team S15-G5, Boczar Spring 2018 USF Tampa, Team S15-G5, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 23
总计 12,634
