跳转到主内容
MSI GE62 6QF Apache Pro Hard Drive Replacement
你所需要的
  1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Hard Drive Replacement, Bottom Case: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Hard Drive Replacement: 步骤 4 中的图像 1,3 MSI GE62 6QF Apache Pro Hard Drive Replacement: 步骤 4 中的图像 2,3 MSI GE62 6QF Apache Pro Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Hard Drive Replacement: 步骤 5 中的图像 1,2 MSI GE62 6QF Apache Pro Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: 步骤 6 中的图像 1,3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: 步骤 6 中的图像 2,3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: 步骤 6 中的图像 3,3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 2,3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 3,3
    • Unscrew the two black PH #0 2mm screws holding the lower part the hard drive plate
    • Unscrew the two PH #0 4mm screws holding the upper part of the hard drive plate
  8. MSI GE62 6QF Apache Pro Hard Drive Replacement: 步骤 8 中的图像 1,2 MSI GE62 6QF Apache Pro Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Remove the hard drive by gently lifting up and pulling the drive out of the connection slot
结论
5等其他人完成本指南。
Justice Owens
于09/26/17注册
604 声望
创作了4篇指南
团队
USF Tampa, Team S2-G3, Passmore Fall 2017 USF Tampa, Team S2-G3, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G3
3 名成员
创作了5篇指南
4条评论
Saved my life, would have had no idea what to do without these instructions and would probably have broke something. My new 2tb ssd is working fine
Simon Porter - 回复
Upgraded the Memory to 32GB and the HDD to a 1TB SATA SSD.
Prabodha Elangasinha - 回复
Only issue I ran into was one of the optical drive screws was frozen in, stripped hard, and I had to fall back on Moodys to break it loose. Once done, everything else was cake.
Chuck Brewer - 回复
My ssd is working fine and the hdd has gone bad on mine... have not even opened mine yet but looking at the pics I wonder where the second drive is located?
Eric Jimenez - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 48
总计 8,229
