跳转到主内容
MSI GE62 6QF Apache Pro Battery Replacement
你所需要的
  1. MSI GE62 6QF Apache Pro Battery Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Battery Replacement: 步骤 2 中的图像 1,1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Battery Replacement, Bottom Case: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Battery Replacement: 步骤 4 中的图像 1,3 MSI GE62 6QF Apache Pro Battery Replacement: 步骤 4 中的图像 2,3 MSI GE62 6QF Apache Pro Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Battery Replacement: 步骤 5 中的图像 1,2 MSI GE62 6QF Apache Pro Battery Replacement: 步骤 5 中的图像 2,2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Battery Replacement, Battery: 步骤 6 中的图像 1,3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: 步骤 6 中的图像 2,3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: 步骤 6 中的图像 3,3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
结论
4等其他人完成本指南。
Justice Owens
于09/26/17注册
604 声望
创作了4篇指南
团队
USF Tampa, Team S2-G3, Passmore Fall 2017 USF Tampa, Team S2-G3, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G3
3 名成员
创作了5篇指南
1指南评论
Excellent guide! Very straightforward with very clear picture. I was able to replace my laptop battery using your tools and following your instruction! 10/10!
Carl Patterson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 49
总计 7,245
