跳转到主内容
MSI Force GC30 V2 Vibration Motor Replacement
你所需要的
  1. MSI Force GC30 V2 Vibration Motor Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
  2. MSI Force GC30 V2 Vibration Motor Replacement: 步骤 2 中的图像 1,3 MSI Force GC30 V2 Vibration Motor Replacement: 步骤 2 中的图像 2,3 MSI Force GC30 V2 Vibration Motor Replacement: 步骤 2 中的图像 3,3
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
  3. MSI Force GC30 V2 Vibration Motor Replacement, Battery: 步骤 3 中的图像 1,1
    • Use tweezers to grip the white battery connector.
    • Pull the battery connector directly out of its port.
    • Do not pull on the wires.
  4. MSI Force GC30 V2 Vibration Motor Replacement: 步骤 4 中的图像 1,1
    • The battery is secured to the motherboard with a mild adhesive. If necessary, apply a small amount of high-concentration isopropyl alcohol beneath the battery to loosen the adhesive.
    • Pry carefully around the battery until it fully releases.
    • Take care not to puncture or bend the battery.
    • Remove the battery.
  5. MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: 步骤 5 中的图像 1,3 MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: 步骤 5 中的图像 2,3 MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: 步骤 5 中的图像 3,3
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 311
