跳转到主内容
MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement
你所需要的
  1. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement, Faucet: 步骤 1 中的图像 1,1
    • Turn the water shutoff valve underneath the sink downwards to stop the flow of water.
  2. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 2 中的图像 1,1
    • Turn the tap(s) on to release any pressure build-up in the pipes.
  3. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 3 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 3 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 3 中的图像 3,3
    • With pliers, unscrew the mounting nuts underneath the sink by turning them counterclockwise.
  4. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 4 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 4 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 4 中的图像 3,3
    • With an adjustable wrench, unscrew the bolts connecting the faucet pipes to the supply lines.
    • After unscrewing the bolts, the faucet pipes should easily come off.
  5. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 5 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 5 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 5 中的图像 3,3
    • Disconnect the lift rod for the drain plug by pushing it off the metal rod.
  6. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 6 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 6 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 6 中的图像 3,3
    • After everything is completely disconnected, pull the faucet out from the top.
  7. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 7 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 7 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 7 中的图像 3,3
    • Clean the area in which the replacement faucet will be placed to ensure that there is a flat surface.
  8. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 8 中的图像 1,2 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 8 中的图像 2,2
    • Insert the pipes of the replacement faucet through the sink holes.
    • Each pipe will correspond to each hole on the right and left.
  9. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 9 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 9 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 9 中的图像 3,3
    • With pliers, tighten the mounting nuts underneath the sink in the same location they were removed from.
  10. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 10 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 10 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 10 中的图像 3,3
    • Reattach the faucet pipes to the supply lines and tighten the bolts with an adjustable wrench.
    • Tighten the left and the right pipe.
  11. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 11 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 11 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 11 中的图像 3,3
    • Reattach the lift rod for the drain plug by lining up the holes and pushing it through the metal rod.
  12. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 12 中的图像 1,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 12 中的图像 2,3 MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 12 中的图像 3,3
    • Turn the shutoff valve upwards to line it up with the pipe and resume the flow of water.
  13. MOEN Adler 4-inch Centerset Single-Handle Bathroom Faucet Replacement: 步骤 13 中的图像 1,1
    • Turn on the tap and inspect for leakage. If any leakage does appear, refer to step 1 & 10 and make the pipe bolts tighter.
    • Otherwise, the replacement sink is completely installed.
结论
To remove the replacement faucet, follow steps 1-6.
Manahal Khalil
于09/11/21注册
217 声望
撰写一个指南
团队
York University, Team E-9, Melo-Thaiss Fall 2021 York University, Team E-9, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG9
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 38
总计 837
