跳转到主内容
MNT Reform SSD Replacement
你所需要的
  1. MNT Reform SSD Replacement, Remove Bottom Plate Screws: 步骤 1 中的图像 1,1
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
  2. MNT Reform SSD Replacement, Remove Bottom Plate: 步骤 2 中的图像 1,1
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
  3. MNT Reform SSD Replacement, Remove Battery Cells: 步骤 3 中的图像 1,2 MNT Reform SSD Replacement, Remove Battery Cells: 步骤 3 中的图像 2,2
    • Pull out the eight battery cells one by one, and set them aside safely.
    • Do not use a metal tool to remove the batteries. You may accidentally short-circuit the metal pins of the battery holders.
    • When replacing the batteries, pay attention to the polarity! Inserting a cell the wrong way in will damage your device.
    • The circuit board indicates the + and - orientation for each cell.
  4. MNT Reform SSD Replacement, Remove SSD Screw: 步骤 4 中的图像 1,1
    • Remove the single M2×4 pan head screw securing the SSD to the motherboard.
  5. MNT Reform SSD Replacement, Remove SSD: 步骤 5 中的图像 1,3 MNT Reform SSD Replacement, Remove SSD: 步骤 5 中的图像 2,3 MNT Reform SSD Replacement, Remove SSD: 步骤 5 中的图像 3,3
    • Lift the free end of the SSD up slightly and pull the SSD straight out of its M.2 socket on the motherboard.
    • To avoid damaging its socket on the motherboard, do not excessively lift the free end of the SSD.
结论
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
另外一个人完成了本指南。
Neelfyn
于05/13/14注册
972 声望
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 609
