跳转到主内容
M3D Micro Z Axis Belt Replacement
  1. M3D Micro Z Axis Belt Replacement, M3D Micro Frame Removal: 步骤 1 中的图像 1,1
    • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
  2. M3D Micro Z Axis Belt Replacement: 步骤 2 中的图像 1,3 M3D Micro Z Axis Belt Replacement: 步骤 2 中的图像 2,3 M3D Micro Z Axis Belt Replacement: 步骤 2 中的图像 3,3
    • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
  3. M3D Micro Z Axis Belt Replacement: 步骤 3 中的图像 1,2 M3D Micro Z Axis Belt Replacement: 步骤 3 中的图像 2,2
    • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
  4. M3D Micro Z Axis Belt Replacement, Z Axis Belt: 步骤 4 中的图像 1,3 M3D Micro Z Axis Belt Replacement, Z Axis Belt: 步骤 4 中的图像 2,3 M3D Micro Z Axis Belt Replacement, Z Axis Belt: 步骤 4 中的图像 3,3
    • Remove the z axis belt from the device by simply lifting each corner of the belt off the corner gears and slide up over the z axis bars.
结论
Danyel Browning
于09/28/17注册
261 声望
创作了2篇指南
团队
USF Tampa, Team S3-G2, Nance Fall 2017 USF Tampa, Team S3-G2, Nance Fall 2017 的会员
USFT-NANCE-F17S3G2
4 名成员
创作了10篇指南
1指南评论
Need a replacement z axis belt for my M3D micro printer don’t know where to go to get one
Ramon Arguello - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 2,284
