跳转到主内容
M3D Micro Nozzle Replacement
你所需要的
  1. M3D Micro Nozzle Replacement, Fan: 步骤 1 中的图像 1,3 M3D Micro Nozzle Replacement, Fan: 步骤 1 中的图像 2,3 M3D Micro Nozzle Replacement, Fan: 步骤 1 中的图像 3,3
    • To release the x-rods, pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks.
  2. M3D Micro Nozzle Replacement: 步骤 2 中的图像 1,3 M3D Micro Nozzle Replacement: 步骤 2 中的图像 2,3 M3D Micro Nozzle Replacement: 步骤 2 中的图像 3,3
    • Slide the tracks off the second slider and remove the printer head and x-tracks from the center of the printer. To remove the front cover of the print head, firmly grip the cover and gently pull it off.
  3. M3D Micro Nozzle Replacement: 步骤 3 中的图像 1,2 M3D Micro Nozzle Replacement: 步骤 3 中的图像 2,2
    • Disconnect the red and black wires at the white connector. They should easily separate.
  4. M3D Micro Nozzle Replacement: 步骤 4 中的图像 1,3 M3D Micro Nozzle Replacement: 步骤 4 中的图像 2,3 M3D Micro Nozzle Replacement: 步骤 4 中的图像 3,3
    • The fan is held loosely in place at the base of the printer head. Use a metal spudger to gently pry it out of the printer head.
  5. M3D Micro Nozzle Replacement: 步骤 5 中的图像 1,1
    • Pull the fan all the way out of the printer head.
  6. M3D Micro Nozzle Replacement, Nozzle: 步骤 6 中的图像 1,2 M3D Micro Nozzle Replacement, Nozzle: 步骤 6 中的图像 2,2
    • To remove the nozzle insulation, grip the insulation and pull it up off of the nozzle.
  7. M3D Micro Nozzle Replacement: 步骤 7 中的图像 1,2 M3D Micro Nozzle Replacement: 步骤 7 中的图像 2,2
    • To remove the nozzle, use a 5 mm nut driver to unscrew it.
结论
3等其他人完成本指南。
Yuliya Marusyk
于09/28/17注册
285 声望
创作了2篇指南
团队
USF Tampa, Team S3-G2, Nance Fall 2017 USF Tampa, Team S3-G2, Nance Fall 2017 的会员
USFT-NANCE-F17S3G2
4 名成员
创作了10篇指南
1指南评论
Do you know where I can source replacement nozzles for this? M3D doesn't have a store page anymore and none of the "standard" nozzles that I've found look like the longer piece that the m3d uses. The one I'm replacing is completely gummed up and stuck on the heating element, so I'm looking to replace both but can't find a source for parts specifically for this model
Omar Tariq - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 3,097
