跳转到主内容
Lytro Camera First Generation Repair
你所需要的
  1. Lytro Camera First Generation Repair, Lytro Camera First Generation Lens: 步骤 1 中的图像 1,1
    • Pull the top off using your hands or the plastic opening tool.
  2. Lytro Camera First Generation Repair: 步骤 2 中的图像 1,1
    • Unscrew the four screws(7.1cm) seen after taking the top off.
  3. Lytro Camera First Generation Repair: 步骤 3 中的图像 1,1
    • Pry that silver piece off that you just took the four screws out of.
  4. Lytro Camera First Generation Repair: 步骤 4 中的图像 1,1
    • Take the camera out of the red part. You should have 3 piece not including the top.
  5. Lytro Camera First Generation Repair: 步骤 5 中的图像 1,1
    • Take the 3 screws(.5) out of the middle piece.
  6. Lytro Camera First Generation Repair: 步骤 6 中的图像 1,1
    • After taking that off you will see the camera lens.
  7. Lytro Camera First Generation Repair: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Pry the piece hanging off with tweezers.
  8. Lytro Camera First Generation Repair: 步骤 8 中的图像 1,1
    • Now you can unscrew the three screws(.5) seen releasing the camera lense from the camera.
  9. Lytro Camera First Generation Repair: 步骤 9 中的图像 1,1
    • After that you can pull it off with the tweezers.
  10. Lytro Camera First Generation Repair: 步骤 10 中的图像 1,1
    • Now that you have it off you can replace it and reverse the steps getting it back together.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 602
