本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show how to lubricate the power dial. Your power dial will operate smooth after completing this guide.
你所需要的
Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
Slide the door off of the battery compartment.
Remove the battery from the phone.
Locate the volume dial on the right side of the telephone.
Remove the volume dial by gently grasping it and pulling it away from the base.
Remove the three 12 mm screws with a Phillips #1 screwdriver.
Remove the three 18 mm screws with a Phillips #1 screwdriver.
Inside base shell on circuit board, lubricate power switch.
另外一个人完成了本指南。
