跳转到主内容
Lovaky PC230A Battery Replacement
你所需要的
  1. Lovaky PC230A Battery Replacement, Battery: 步骤 1 中的图像 1,2 Lovaky PC230A Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off the keyboard by sliding the power switch to the off position. The switch is located on the top right of the front of the keyboard.
    • Make sure that the keyboard is powered off before beginning to do any work on it. Working on the device with the power on can possibly lead to electric shock.
  2. Lovaky PC230A Battery Replacement: 步骤 2 中的图像 1,2 Lovaky PC230A Battery Replacement: 步骤 2 中的图像 2,2
    • Turn over the keyboard and remove the cover to the battery compartment by lifting the tab of the battery cover up and off.
    • You can use your fingernail to do this or a wedging tool to help remove the battery cover.
    • Take the faulty battery out of the battery compartment by pushing the battery towards the spring and lifting the other end of the battery out of the compartment.
    • When inserting the new battery make sure the flat side goes against the spring and the studded side goes against the flat side.
结论
Sadie Bickford
于03/18/24注册
135 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-5, Konn Spring 2024 UMass Dartmouth, Team 2-5, Konn Spring 2024 的会员
UMASSD-KONN-S24S2G5
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 57
