跳转到主内容
Lorex LW2744 Wi-Fi Antenna Replacement
你所需要的
  1. Lorex LW2744 Wi-Fi Antenna Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the 5.0mm screw using the Phillips #0 head screwdriver.
  2. Lorex LW2744 Wi-Fi Antenna Replacement: 步骤 2 中的图像 1,1
    • Insert metal spudger as shown in the picture. Move spudger along to the other side until both snaps come loose.
  3. Lorex LW2744 Wi-Fi Antenna Replacement: 步骤 3 中的图像 1,1
    • Picture shows the removed battery cover.
  4. Lorex LW2744 Wi-Fi Antenna Replacement: 步骤 4 中的图像 1,1
    • Slide the battery out by pulling on one of two plastics tabs.
  5. Lorex LW2744 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 5 中的图像 1,1
    • Remove the remaining five 6.0 mm Phillips #0 screws.
  6. Lorex LW2744 Wi-Fi Antenna Replacement: 步骤 6 中的图像 1,1
    • Use the spudger to remove the back cover. Insert the spudger between the back and front cover. Once inserted, you will need to move it around the perimeter to release the snaps holding it together.
  7. Lorex LW2744 Wi-Fi Antenna Replacement: 步骤 7 中的图像 1,1
    • Once back cover is removed, the speaker wire will need to be removed. Use tweezers to remove wire.
  8. Lorex LW2744 Wi-Fi Antenna Replacement: 步骤 8 中的图像 1,1
    • Begin by heating the exposed end of the grey lead with the tip of a soldering iron while simultaneously pulling the lead away from the connection, using tweezers to grasp the lead by the insulation.
    • For more information on soldering, check out this repair guide: iFixit Soldering
结论
Yancey Crase
于03/26/18注册
217 声望
创作了2篇指南
团队
IUPUI, Team S1-G4, Harley Spring 2018 IUPUI, Team S1-G4, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G4
7 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 254
