跳转到主内容
Lorex LW2742 Speaker Replacement
你所需要的
  1. Lorex LW2742 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,3 Lorex LW2742 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,3 Lorex LW2742 Speaker Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
    • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
  2. Lorex LW2742 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
  3. Lorex LW2742 Speaker Replacement: 步骤 3 中的图像 1,2 Lorex LW2742 Speaker Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
    • Carefully remove the back panel
    • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
  4. Lorex LW2742 Speaker Replacement, Speaker: 步骤 4 中的图像 1,3 Lorex LW2742 Speaker Replacement, Speaker: 步骤 4 中的图像 2,3 Lorex LW2742 Speaker Replacement, Speaker: 步骤 4 中的图像 3,3
    • Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
  5. Lorex LW2742 Speaker Replacement: 步骤 5 中的图像 1,2 Lorex LW2742 Speaker Replacement: 步骤 5 中的图像 2,2
    • Using a metal spudger, pry the melted black plastic away from the speaker.
    • Carefully pull the speaker out of its housing by the wires.
结论
另外一个人完成了本指南。
Alex Kusmierz
于09/26/16注册
601 声望
创作了5篇指南
团队
USF Tampa, Team 16-1, Eyestone Fall 2016 USF Tampa, Team 16-1, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 320
