跳转到主内容
Lorex LW2742 LCD Display Replacement
你所需要的
  1. Lorex LW2742 LCD Display Replacement, Back Panel: 步骤 1 中的图像 1,3 Lorex LW2742 LCD Display Replacement, Back Panel: 步骤 1 中的图像 2,3 Lorex LW2742 LCD Display Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
    • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
  2. Lorex LW2742 LCD Display Replacement: 步骤 2 中的图像 1,1
    • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
  3. Lorex LW2742 LCD Display Replacement: 步骤 3 中的图像 1,2 Lorex LW2742 LCD Display Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
    • Carefully remove the back panel
    • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
  4. Lorex LW2742 LCD Display Replacement, LCD Display: 步骤 4 中的图像 1,3 Lorex LW2742 LCD Display Replacement, LCD Display: 步骤 4 中的图像 2,3 Lorex LW2742 LCD Display Replacement, LCD Display: 步骤 4 中的图像 3,3
    • Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
  5. Lorex LW2742 LCD Display Replacement: 步骤 5 中的图像 1,1
    • Remove the two 5mm Phillips #1 screws that are holding the motherboard in place.
  6. Lorex LW2742 LCD Display Replacement: 步骤 6 中的图像 1,2 Lorex LW2742 LCD Display Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Peel away the yellow tape that is covering the large harness.
    • Use needle-nosed tweezers to pull out the black tabs that are holding the film in the harness and gently pull the film out of the harness.
  7. Lorex LW2742 LCD Display Replacement: 步骤 7 中的图像 1,2 Lorex LW2742 LCD Display Replacement: 步骤 7 中的图像 2,2
    • Flip the back panel and motherboard over to reveal the back of the LCD monitor
  8. Lorex LW2742 LCD Display Replacement: 步骤 8 中的图像 1,2 Lorex LW2742 LCD Display Replacement: 步骤 8 中的图像 2,2
    • The LCD monitor will easily come out of the front casing of the monitor.
结论
另外一个人完成了本指南。
Alex Kusmierz
于09/26/16注册
601 声望
创作了5篇指南
团队
USF Tampa, Team 16-1, Eyestone Fall 2016 USF Tampa, Team 16-1, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G1
4 名成员
创作了12篇指南
4指南评论
I need the price list of this Lorex LW2742 LCD Display Replacement
ADETAYO - 回复
I have the Lorex and I need a new ftat flexible cable, the number on the cable is S13821. This cable broke off as i did not use Ifixit at first.
Pierre DePass - 回复
I have the Lorex and I need a new flat flexible cable, the idea here was to get to the DC supply and remove the plug in component as it was damage because of constant useage of plug in in and out. The Flat Flexible Cable Number is S13821
Pierre DePass - 回复
I have a Loren 7'' wireless monitor and I need to get a replacement battery model 4170102 where can I get one
Micky Shoemaker - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 32
总计 1,675
