跳转到主内容
Longboard or Skateboard Truck Maintenance
你所需要的
  1. Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: 步骤 1 中的图像 1,2 Longboard or Skateboard Truck Maintenance, Longboard or Skateboard Truck Maintenance: 步骤 1 中的图像 2,2
    • Use a Phillips/flat head screw driver, along with a skate tool or set of pliers, to loosen the nuts which fasten the trucks to the deck.
  2. Longboard or Skateboard Truck Maintenance: 步骤 2 中的图像 1,1
    • Use your fingers to fully loosen and remove the nuts from the bolts.
    • Nuts are small and easy to lose track of.
  3. Longboard or Skateboard Truck Maintenance: 步骤 3 中的图像 1,3 Longboard or Skateboard Truck Maintenance: 步骤 3 中的图像 2,3 Longboard or Skateboard Truck Maintenance: 步骤 3 中的图像 3,3
    • Use your hands to remove the trucks from the deck.
    • Make sure the kingpin is facing outward, If the kingpin is not properly reinstalled, the trucks will fail to perform properly.
  4. Longboard or Skateboard Truck Maintenance: 步骤 4 中的图像 1,1
    • Remove the truck raiser if applicable.
  5. Longboard or Skateboard Truck Maintenance: 步骤 5 中的图像 1,2 Longboard or Skateboard Truck Maintenance: 步骤 5 中的图像 2,2
    • Remove the bolts from the factory drilled holes on the deck.
    • Note that the bolts are small and easy to lose track of.
  6. Longboard or Skateboard Truck Maintenance: 步骤 6 中的图像 1,1
    • Clean the deck with a moist cloth or cleaning solution.
  7. Longboard or Skateboard Truck Maintenance: 步骤 7 中的图像 1,1
    • Clean the trucks with a moist cloth or cleaning solution.
  8. Longboard or Skateboard Truck Maintenance: 步骤 8 中的图像 1,2 Longboard or Skateboard Truck Maintenance: 步骤 8 中的图像 2,2
    • Clean the hardware by either soaking it in cleaning solution, or by manually cleaning it with a moist cloth.
  9. Longboard or Skateboard Truck Maintenance: 步骤 9 中的图像 1,1
    • Repeat steps 1-7 with the second truck.
  10. Longboard or Skateboard Truck Maintenance: 步骤 10 中的图像 1,1
    • After re-installation, check and confirm that all the bolts and nuts are tight. The bolts should be slightly submerged in the wood of the deck
    • Over tightening the bolts can cause them to strip.
    • Failure to tighten the bolts and nuts properly may lead to improper performance.
  11. Longboard or Skateboard Truck Maintenance: 步骤 11 中的图像 1,2 Longboard or Skateboard Truck Maintenance: 步骤 11 中的图像 2,2
    • After re-installing the trucks, check and confirm the kingpin is facing outward.
    • Failure to do this will cause the longboard's functions to be inverted, which may lead to personal injury.
结论
Now you’ve completed the guide ‘How to clean and maintain skate/longboard trucks. Your longboard should look like the picture. Before riding, as a final precaution, make sure every piece is securely fastened and the trucks are facing the correct way. Have fun and always wear a helmet!
另外一个人完成了本指南。
Dominic Turano
于09/21/15注册
122 声望
撰写一个指南
团队
Colorado Springs, Team 6-2, Mcmichael Fall 2015 Colorado Springs, Team 6-2, Mcmichael Fall 2015 的会员
UCCS-MCMICHAEL-F15S6G2
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 7,416
