跳转到主内容
Logitech Webcam Pro 9000 Motherboard Replacement
你所需要的
  1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: 步骤 1 中的图像 1,2 Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Motherboard Replacement: 步骤 2 中的图像 1,2 Logitech Webcam Pro 9000 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 步骤 3 中的图像 1,3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 步骤 3 中的图像 2,3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 步骤 3 中的图像 3,3
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
  4. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: 步骤 4 中的图像 1,2 Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: 步骤 4 中的图像 2,2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  5. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: 步骤 5 中的图像 1,2 Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
  6. Logitech Webcam Pro 9000 Motherboard Replacement: 步骤 6 中的图像 1,2 Logitech Webcam Pro 9000 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
  7. Logitech Webcam Pro 9000 Motherboard Replacement, Camera: 步骤 7 中的图像 1,1
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
  8. Logitech Webcam Pro 9000 Motherboard Replacement: 步骤 8 中的图像 1,3 Logitech Webcam Pro 9000 Motherboard Replacement: 步骤 8 中的图像 2,3 Logitech Webcam Pro 9000 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Remove the camera from the motherboard by desoldering the two connections as shown.
结论
另外一个人完成了本指南。
Cory Davis
于04/14/13注册
236 声望
创作了4篇指南
团队
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G34
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 2,322
