跳转到主内容
Logitech Webcam Pro 9000 Microphone Replacement
你所需要的
  1. Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: 步骤 1 中的图像 1,2 Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Microphone Replacement: 步骤 2 中的图像 1,2 Logitech Webcam Pro 9000 Microphone Replacement: 步骤 2 中的图像 2,2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: 步骤 3 中的图像 1,2 Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: 步骤 3 中的图像 2,2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  4. Logitech Webcam Pro 9000 Microphone Replacement, Microphone: 步骤 4 中的图像 1,3 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: 步骤 4 中的图像 2,3 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: 步骤 4 中的图像 3,3
    • Wedge the plastic opening tool into the crack between the plastic cover and microphone guard.
    • Use the wedge to separate the two pieces.
    • It might take more force than expected.
  5. Logitech Webcam Pro 9000 Microphone Replacement: 步骤 5 中的图像 1,3 Logitech Webcam Pro 9000 Microphone Replacement: 步骤 5 中的图像 2,3 Logitech Webcam Pro 9000 Microphone Replacement: 步骤 5 中的图像 3,3
    • Twist the rubber casing and remove it from the plastic cover.
结论
2等其他人完成本指南。
nieko
于04/18/13注册
63 声望
创作了2篇指南
团队
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G34
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,238
