跳转到主内容
简介
Prerequisite only guide to open the Logitech VX Nano Wireless Mouse.
  1. Pull down on the battery release tab to remove the battery cover. Remove battery cover.
    • Pull down on the battery release tab to remove the battery cover.
    • Remove battery cover.
  2. Pull the battery release tab away from the mouse so the two AA batteries come out. Pull the battery release tab away from the mouse so the two AA batteries come out.
    • Pull the battery release tab away from the mouse so the two AA batteries come out.
  3. If the Nano Receiver is still in the mouse and not in your computer, remove it by pushing on the bright orange button. It should pop right out!
    • If the Nano Receiver is still in the mouse and not in your computer, remove it by pushing on the bright orange button. It should pop right out!
  4. Find and remove the screws at the bottom of the battery compartment:
    • Find and remove the screws at the bottom of the battery compartment:
    • Two 6 mm Phillips #1 screws
    • When removing these two screws, it can be helpful to hold the plastic battery tab out of the way of your screwdriver.
  5. Use an opening pick to get underneath the corner of one of the adhesive skates. As you start to remove the skate, make sure that the opening pick is underneath the entire adhesive pad—otherwise you run the risk of splitting the pad in half.
    • Use an opening pick to get underneath the corner of one of the adhesive skates.
    • As you start to remove the skate, make sure that the opening pick is underneath the entire adhesive pad—otherwise you run the risk of splitting the pad in half.
    • Continue to push the opening pick between the adhesive and the mouse case, slowly working the adhesive away from the case.
    • Repeat this same process for the two other skates.
    • Remove any old adhesive residue before applying new mouse skates.
  6. Remove the screws from the backside of the mouse:
    • Remove the screws from the backside of the mouse:
    • Three 6 mm Phillips #1 screws
    • The top shell and bottom case are no longer connected. Keep the mouse steady so you can carefully remove the upper shell in the next step.
  7. Carefully separate the top plastic shell from the bottom case. Remove the top shell.
    • Carefully separate the top plastic shell from the bottom case.
    • Remove the top shell.
结论
Carsten Frauenheim
于2020年03月10日注册
45,571 信誉积分
创作了256篇指南
团队
iFixit iFixit 的会员
Community
137 名成员
创作了16,041篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 16
